Will A Rear axle off of a 2000 GT fit on my 86 GT?
Old 07-24-2011, 08:23 PM
jeremie1219
jeremie1219's Avatar
Default Will A Rear axle off of a 2000 GT fit on my 86 GT?
ok so i have a 86 GT and im trying to do a 5 lug conversion. i just picked up a 2000 GT rear end and i wanna swap my rear end out for that one. i heard it can be done but the axle housing is about 3/4 of an in bigger on each side. will it work? do i need to get shorter axles? help please!!!
jeremie1219 is offline
Old 07-25-2011, 12:36 AM
jimkaray
jimkaray's Avatar
It will bolt up no problem but the overall length may cause your tires to rub the wheel wheel. I believe the 2000 is more than 3/4" wider so either research or measure it. You'll then need to buy wheels that have an offset that will compensate for the wider track. Sure you could have the tubes and axles shortened but the cost is going to be more than its worth.
jimkaray is offline
Old 07-25-2011, 04:21 AM
mustangGT86_05
mustangGT86_05's Avatar
your question is very miscategorized btw, but I just installed a turbo coupe rear end in mine that is 3/4 wider per side also, and I do not run into tire rubbing issues. In fact, caused my cobra r's to line up flush with my quarter panels. If you intend to lower it, you will need to figure out how to prevent rub. Theres everything from converting the length of your axles, to different offset wheels to rolling the quarters up some, just depends what you intend to do
You also will need to convert the brake system to compensate for the disc conversion, rear drums have a much different setting than disc, I'm in the process of finishing this on mine
mustangGT86_05 is offline
Old 07-25-2011, 08:37 PM
jeremie1219
thankyou for your help. after looking at it i decided just to take off the backing plate frome the 2000 axle cause after looking at it i realized that it def not an 8.8 and must be off of a 2000 v6 not a gt.(rookie mustake i know) i have a new question tho. the backing pates bolted right onto my 86 rear end right where the drum breaks were bolted. if i go get 99-04 calipers, rotors and 5 lug axle shafts will this work?
Old 07-26-2011, 09:19 PM
mustangGT86_05
your rear end didnt come with them on it? It should, I dont want to say 100%, but they usually keep things interchangeable. You will most likely have to do some brake line adapting
Old 07-26-2011, 09:48 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
not really...
its gonna be almost 2" wider and the hardware is 12mm vs your 14mm so itll take a little bit of work...
IMO just find a 94-98 rear thats a direct bolt in for the most part
sn95_331_GT_ yellow is offline
Tivo304
08-28-2023 12:19 PM
11-10-2015 11:39 AM
Dragonus18
09-09-2015 01:21 AM
Jose Corretjer
09-08-2015 06:32 AM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Will A Rear axle off of a 2000 GT fit on my 86 GT?
