powerdyne install question
Old 07-28-2011, 05:09 PM
02gtwhite
02gtwhite's Avatar
Default powerdyne install question
I am getting ready to install a bd11a powerdyne running 8# of boost. i have 24# injestors and 75mm mass air already and 255 walbro fuel pump. should i upgrade to 30# injectors and do i need a tune for this. I know powerdynes junk but i got a good deal and wanna try it out. any help would be great
02gtwhite is offline
Old 07-28-2011, 06:22 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
I would upgrade to 42lbs if it was me. You can get away without a tune but get one to be safe.
projectresto83 is offline
Old 07-29-2011, 10:06 AM
g3mustang
g3mustang's Avatar
with 42's you need a tune
g3mustang is offline
Old 07-29-2011, 10:12 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if you are running and fmu with said set up, then you can get away with it, I run a full h/c/i and a t-trim with 7-9 psi on and fmu with 24's, but I have a boost retard set very conservative and I run a AFM inline big pump as a kicker, soon I will add a 12 lb pulley and when I do I will run 42's a larger maf and a tune for sure, oh and my above set up has no tune, is it optimal?? no , does it work?? yes for the time being, 42's would be the safe bet with proper maf and a dyno tune so you know a/f is optimal through a full pull
mjr46 is offline
Old 07-29-2011, 10:45 AM
projectresto83
M.A.D. Motorsports
Exactly, I have personally seen a few built 302s running over 10psi on the stock a9l. U just have to know how to tweak the timing and fuel pressures
Old 07-29-2011, 11:14 AM
g3mustang
g3mustang's Avatar
i have no tune fmu and 30's i was just saying with 42 you would need a tune. mainly for start up and idle
Old 07-29-2011, 01:19 PM
AdderMk2
Banned
AdderMk2's Avatar
*open trash can*
*deposit powerdyne*
*close trash can*
*walk away*
:Installation complete:
AdderMk2 is offline
Old 07-29-2011, 02:52 PM
67mustang302
67mustang302's Avatar
Originally Posted by AdderMk2
*open trash can*
*deposit powerdyne*
*close trash can*
*walk away*
This was my thought as well.
67mustang302 is offline
drfister
05-03-2018 10:38 PM
GimpyHSHS
08-29-2015 06:30 PM
toastintx64
08-29-2015 05:12 PM
whatsup62
08-29-2015 01:25 PM
Shifty Magoo
08-25-2015 03:08 PM
Quick Reply: powerdyne install question
