95gt vibration under heavy acceleration
Old 08-04-2011, 05:47 PM
frststang
frststang's Avatar
Default 95gt vibration under heavy acceleration
im about to look at a 95 gt tha has a vibration to it guy says its almost nonexsistent when driving normal but under hard acceleration theres vibration car has this as folows car has 152k
upr chromoly control arms (uppers and lowers), upr diff snubber, and new diff housing bushings. The car has the original posi ,with 3.73 gears,and will need to be replaced due to the high mileage, but I have a like new 28 spline posi that I will include with the car. The car runs and drives great but the rear end has a vibration under heavy acceleration. Suspension: KYB 9 way adjustable shocks, eibach springs, sub frame connectors, stock front swaybar, and hotchki caster camber plates, and the car rides on 99-04 GT wheels and nexen tires that have about 30% tread.
is there anything i should look into that could cause this vibration he seems to think its do to the milage of the car could this be?
frststang is offline
Old 08-04-2011, 07:45 PM
TexasTanker19kilo20
Goldilocks
TexasTanker19kilo20's Avatar
From what you posted the vibration is in the rear end or is it a motor/wheel vibration? Need more detail.
TexasTanker19kilo20 is offline
Old 08-04-2011, 08:40 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
look at the UCA mounts on the body, more than likely the poly bushings ruined them and the torque under WOT is cause the rear to move a little bit...
poly bushings = fail............
sn95_331_GT_ yellow is offline
mtgldr
02-03-2024 09:00 PM
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
mdj89
09-23-2015 08:49 AM
LivingInThePast
09-16-2015 12:20 PM
Quick Reply: 95gt vibration under heavy acceleration
