headbolt torque question
Old 08-12-2011, 11:58 PM
kennebellgt
kennebellgt's Avatar
Red face headbolt torque question
Mods in signature, I just installed new head gaskets and I torqued my head bolts down to 80/80. Do you think this will be ok? I understand now that it was supposed to go 70/80 but everything in almost done, lmk what you think,
Thanks
Edit: I used arp head bolts (new)
kennebellgt is offline
Old 08-13-2011, 12:34 AM
67mustang302
67mustang302's Avatar
Did you follow the torque sequence?
67mustang302 is offline
Old 08-13-2011, 12:05 PM
kennebellgt
Yes, I made sure of that, I went by the chiltons manual head bolt tightening sequence and went 20-40-60 and final to 80lbs
Old 08-13-2011, 01:43 PM
67mustang302
It's probably ok. The reality is that torque is a really inaccurate way of controlling bolt stretch. If you torqued it to 80, that means it's probably somewhere between an actual 70-90lbs, depending on how accurate your torque wrench is, what you used for thread lube etc.
Old 08-13-2011, 01:52 PM
kennebellgt
yeah I used arp lube and sealer, I just hope its okay being that my upper bolt are supposed to be higher than the bottoms.
Old 08-13-2011, 09:01 PM
tinman
tinman's Avatar
I've run them the same way as you have yours. Never had anything bad happen yet.
I no longer run them that way however.....
tinman is offline
Old 08-13-2011, 11:36 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I run 85 top and 80 bottom, expecially if you are running a poweradder such as myself
mjr46 is offline
Old 08-13-2011, 11:46 PM
kennebellgt
I tried to go 85 for the uppers but my torque wrench wouldn't let me go the extra 5lbs just kept clicking.
Old 08-13-2011, 11:48 PM
mjr46
mjr46's Avatar
you need a new torque wrench then, throw that POS away.
mjr46 is offline
Old 08-14-2011, 11:34 AM
67mustang302
It depends. If you torque something to 80lbs, then try to torque to 85, the breaking torque to get the bolt rotating once it was set at 80, may be as high as 90-100 to get rotation started. Sometimes more. You have to overcome the friction of the threads, bolt head etc etc, and it takes more torque to start turning than to actually turn it.
That's also why I lube the underside of the bolt head, washers etc. Anywhere there's contact there's friction.
Quick Reply: headbolt torque question
