What combo to use??? 450 rwhp goal...
Old 10-13-2011, 04:37 PM
opie_803
opie_803's Avatar
I am also looking at the on3 system around the first of the year. my current set up includes 24# injectors and matching 70mm MAF and TB, 255 fuel pump, 1.7 rr, Gt40 upper and lower intake. the heads and cam are stock. the previous owner had a s/c on it but pulled it off prior to selling the car. i know my injectors will be a limiting factor but can they be used temporarily? i was hoping i could utilize what i have since it used to support a s/c.
opie_803 is offline
Old 10-13-2011, 06:34 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
no^^^^^^^^^^^^ not when you have the turbo, I run a s/c with 12 lbs and it has 24's with an fmu but I have never gone WOT very long and never taken each gear to max rpm, just quick short bursts and that's with an fmu, you should at least get 42's, I will be doing such soon, you could use them just to drive around but you'd be dumb to ever go under boost with them.
mjr46 is offline
Old 10-13-2011, 07:29 PM
OiDALE
OiDALE's Avatar
What do you guys think of cast iron ported Windsor Sr. heads with my set up and the turbo...? I will keep the bottom stock. Are these heads an overkill or...
I thought the heads that my buddy had were vics but just varified that they are windsor Sr.
OiDALE is offline
Old 10-13-2011, 11:25 PM
opie_803
opie_803's Avatar
mjr46, thanks for the reply. i will def. get larger injectors then. this project is still a few months or so away and more time to do research before any money is spent.
opie_803 is offline
Old 10-17-2011, 09:41 AM
OiDALE
OiDALE's Avatar
Ok, I passed on the windsor Sr and a set of afr 185 because I know that they will not work with the stock lower.
I think I will wait around for some TFS TWisted wedges, with the smaller 1.94 I beleive thats what they are? What exaclty should I be looking for, is there just one type of twisted wedge? Thanks guys, Im still going turbo but I think it makes sense to do the heads and maybe a cam before the hairdryer...
OiDALE is offline
Old 10-17-2011, 11:41 AM
mjr46
mjr46's Avatar
tfs tw 170 cc will be fine and they don't have 1.94's they have 2.02/ 1.60 and work with stock bottom ends
mjr46 is offline
Old 10-17-2011, 08:00 PM
OiDALE
OiDALE's Avatar
Those are what im going to look for...Thanks man.
OiDALE is offline
Old 12-15-2011, 05:32 PM
OiDALE
OiDALE's Avatar
Hello, Im back...It took a while but I just picked up a set of used Trickflow twisted wedge 170's. I will have them looked over and install farrea valves and springs and putting on some crane 1.6 roller rockers.
My next hunt will be a cam??? Just to recap, low mileage Stock 302 bottom...I will have the 170cc twisted wedges mentioned, Holley Systemax 2 with 2" spacer, 70mm TB, 75mm Egr Spacer, 80mm mac maf, 30# injectors, fender cold are intake, Mac long tubes 1 3/4 with prochambers-side dumps and a set of 3.55 gears...
Which cam would be best for a street car that this is. I never take it to the track and I will be spraying it (approx 100/120hp wet) to reach my desired goal of approx 450rwhp until I can afford a low psi blower down the road or a turbo. So whats a good cam for my street car with a/c??? Im looking into the Andersons n-41???
Any help will be really appreciated....Thanks!
OiDALE is offline
Old 12-16-2011, 04:11 PM
OiDALE
OiDALE's Avatar
Any thoughts on a E303 cam with my set up along with 1.7 rockers instead of the 1.6???
OiDALE is offline
Old 12-17-2011, 12:00 AM
Tony71502
Tony71502's Avatar
Your rocker arm size should depend on the lift of your cam. I'm not a fan of Ford letter cams...
Tony71502 is offline
Quick Reply: What combo to use??? 450 rwhp goal...
