I grabbed an Explorer intake as well as the maf off of the explorer. My 93 has a round clip with 4 pins. The explorer maf has a square clip with 4 pins. Is this the same maf with a different clip or is it totally different?
Thanks for the advice guys. I was told at pick and pull that stock mafs aren't calibrated for a certain type of injector, only aftermarket mafs are. He said that as long as the maf has a certain part # on it I would be fine, which it did. Guess I should probably just buy larger injectors and a matched maf considering I have aluminum heads, explorer intake, and a trickflow stage 1 cam.
