need help building 5.0
Old 11-11-2011, 11:17 PM
92stangerGT
92stangerGT's Avatar
Default need help building 5.0
I have a 92 gt I have a stock pair oh heads for it that I'm planning on doing a value job and porting and its getting a cam and such does any one know how big the values can be and how big of a lift for the can to go thanks
92stangerGT is offline
Old 11-12-2011, 02:18 AM
primetime5.0
primetime5.0's Avatar
you're wasting your money
primetime5.0 is offline
Old 11-12-2011, 07:28 AM
92stangerGT
What would you do then
Old 11-12-2011, 08:31 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Stick with the stock cam.....
At the very least get some GT40's
Wait till you have the heads, an intake, and cam before you swap any of it.
projectresto83 is offline
Old 11-12-2011, 02:36 PM
92stangerGT
I was planing on doing everything but a couple people said the stock heads arnt bad
Old 11-12-2011, 08:06 PM
lxman1
lxman1's Avatar
They work ok with the stock cam, but you won't gain anything with a bigger cam unless you have a lot of work done to them, which isn't cost effective with all of the aftermarket heads available.
lxman1 is offline
Old 11-12-2011, 08:14 PM
projectresto83
M.A.D. Motorsports
The heads are the only item in the 3 that I would change by itself. Swapping the intake, TB, and MAF first does help but not much. Better throttle response.....
Old 11-12-2011, 11:14 PM
tinman
tinman's Avatar
Those stock heads are the bottleneck.
Can't really change them without doing the cam and intake also.....
tinman is offline
Old 11-13-2011, 11:42 AM
92stangerGT
So if I was gunman new heads a cam and intake what ones would you Guys get
Old 11-13-2011, 11:55 AM
projectresto83
M.A.D. Motorsports
That just depends on how much money you have to spend, what your goals are and how often you plan on driving it.....
Quick Reply: need help building 5.0
