450 rwhp at 4800 rpm
finally i got my car fixed and dyno tune and as you can see the title it ran out of injectors. i have 30lbs but i need 42lbs injectors. would like to get some feed back from youll on injectors brand cause i have been reading the feed back on the venom injectors and its not good. ford racing said they dont make 42lbs any more only 39lbs or 47lbs. also what 1/4et should i be doing.
@ tinman
93 notch
3:55 gear ratio
Tko 500
302 bored .040 with flat top
X303 cam
Performer Edelbrock heads
Trick flow r series intake
75mm tb
255 fuel pump
30lbs objectors
V-1 vortech supercharger 10lbs
Would like to put this on my file but don't know how yet
Also some pic or video
93 notch
3:55 gear ratio
Tko 500
X303 cam
75mm tb
255 fuel pump
30lbs objectors
@ army
Well over 4800 rpm it runs lean so that's the reason why I need bigger objectors. Then I can know how much rwhp at 6000 rpm. Not bad for my first build and this forum helped a lot cause I read and asked questions. But since u say I could go bigger then 42lbs what about 47lbs cause ford racing do have those.
