Boss blocks?
Old 11-30-2011, 09:57 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
Originally Posted by Venomantidote95
Well you can get the boss in big bore at a prefinish of 4.115.... What special items are needed like screwin plugs shorter 1/2in studs etc....
DART blocks are finished, they dont need the final honing like the BOSS blocks do...
sn95_331_GT_ yellow is offline
5.0kid
5.0kid's Avatar
Ok I never said it came machined in a final spec! These issues are why im asking now! Therefore no offense will be taken. I have been thinking hard on the shp just to be safe... The build is about 2mths out im in the homework stage now next month parts ordering then the machining etc... I have a point to prove with some spoiled mom and pop funded egomaniacs here locally... I cant spray my stock block enough without needing a stainless firewall to get the point across...
as I find new questions ill post here and see what you guys have to offer... Thanks so far!
Was not talking about you when i mentioned machine work it was to the guy that said the dart doesnt need as much machine work. Sorry if that came across wrong
5.0kid is offline
Old 11-30-2011, 10:26 PM
Venomantidote95
Venomantidote95's Avatar
No worries as for machining lol you would be a moron to final hone a bore any spec since you dont know the exact piston fitment! In a set of 8 2 might be number spot on spec thats why there +- in the specs... This is far from my first engine but is the first aftermarket block build otherwise this thread wouldnt exist.
Venomantidote95 is offline
Old 11-30-2011, 10:47 PM
5.0kid
5.0kid's Avatar
agreed, i guess im not really getting my point across to others (not you) in that people talk about blocks needing more or less machining. Either way if your gonna buy a 2000+ dollar block machine work should not be part of your budget. most people dont realize its more then just boring the block and decking it. Lifters holes need work and bushings (id suggest bronze) along with a whole lot of other things. Thats what i was really getting at. If you spend the money for an aftermarket block whether or not it needs more or less machine work to get it ready to build shouldnt be of a concern because your gonna have it all done anyways
5.0kid is offline
Old 12-01-2011, 12:24 AM
Venomantidote95
Gotcha if you know of the finishing needs pm me the heads up if you dont mind I have a long way to go and time to get there!
Old 12-03-2011, 09:46 AM
TrimDrip
FudgeDrip
TrimDrip's Avatar
I think the biggest you can go with a boss block is a big bore 347 and not have the issues mike stated.
TrimDrip is offline
Old 12-04-2011, 08:10 PM
Venomantidote95
Well since the bb is the 363 unit the idk what issues could occur since the bore is the only factor not piston hieght... If the cylinders were shorter then anything over a 331 would be too much right or am I not seeing the (problems).
Old 12-04-2011, 08:27 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
the cylinder skirts are the prob, they are too short, the stroker pulls the piston nearly out, which is why the boss block uses special pistons, meaning shorter skirts, but that in itself causes issues/longevity cause it allows piston rock.....I'll see if i can find the thread on the corral that addresses this issue
mjr46 is offline
Old 12-04-2011, 08:49 PM
mjr46
mjr46's Avatar
here, this is the only one I can find at the moment but when woody/ ford strokers and Mark O'NEAL /owner CHP say they won't do them, there is a good reason.
http://forums.corral.net/forums/5-0-...d-you-use.html
mjr46 is offline
Old 12-05-2011, 12:06 AM
Venomantidote95
Ok so my 331 statement is accurate?! I got it now thanks again.
GimpyHSHS
19
12-19-2023 01:12 PM
PaulH2
20
01-31-2016 09:48 AM
UrS4
09-30-2015 10:13 AM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: Boss blocks?
