caster and chamber problem, maybe.
what im wanting to know, have a 93 mustang with aftermarket (GRIPP) caster and chamber plates. For about a month now, as i make turns, a pop comes from the passenger side front tire. A couple people have told me its the chamber plate, that the bushing is bad.?. Can this be fixed? Is that even the problem? I noticed when i had that side jacked up that when i wiggle the tire i can see the shock move a little.
No disrespect intended, but I think the reason he posted was to get information so he wouldnt have to take it all apart.
I'd second the loose bolt theory. Tighten every bolt you see, starting under the hood on the strut tower and work your way down. Then drive it and see if it cleared up. If not, see above post. LOL
uberstang1
09-20-2015 06:42 PM
09-10-2015 08:39 PM
