phenolic spacer or no??
Old 01-31-2012, 02:07 PM
StalkerGT
StalkerGT's Avatar
Default phenolic spacer or no??
I have a trick flow street intake and im going to be ordering a new hardware kit and gasket for the upper to lower...saw that a heat spacer with hardware and gaskets was only about 10 more dollars. Do they make a difference? Thanks!
StalkerGT is offline
Old 01-31-2012, 03:53 PM
Tony71502
Tony71502's Avatar
Slight difference, spacer creates higher air velocity slightly helping low end torque but slightly hurting top end power. It may reduce upper intake temps a few degrees.
Choice is yours to make. Make sure you have hood clearance if you get it.
Tony71502 is offline
Old 01-31-2012, 07:33 PM
Bubba 95SN
Bubba 95SN's Avatar
I used spacer to clear the taller valve covers I purchased.
Bubba 95SN is offline
Old 01-31-2012, 08:10 PM
Shelty
Shelty's Avatar
like what tony said. but you need the hood clearance.
Shelty is offline
Old 02-01-2012, 07:04 AM
StalkerGT
StalkerGT's Avatar
clearance won't be a problem...i have a cobra R with svo scoop hood. Might as well just spend the extra 10 and get it!
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
Webster454
09-07-2015 04:59 AM
BigWave916
Wheels & Tires
09-02-2015 08:26 AM
Wesley1995
08-30-2015 02:01 PM
mtxplod
08-29-2015 01:43 AM
Quick Reply: phenolic spacer or no??
