T5-Z wont shift when warm
Old 02-16-2012, 05:05 PM
Pony 5.0
Pony 5.0's Avatar
Default T5-Z wont shift when warm
I have a T5-Z in my 90 GT that I bought new. Lately, it has been hard to shift into first gear after it has warmed up. While sitting at a light, I usually pop it into neutral, then when I try to shift it back into first, it feels as if I am hitting a wall. If the car is moving slightly, it will engage however. Any clues?
Pony 5.0 is offline
Old 02-16-2012, 05:20 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
do you have a stock clutch cable and quadrant or aftermarket cable and quadrant?? if ifs adjustable sounds like the clutch is not fully disengaging/ needs adjusting
mjr46 is offline
Old 02-16-2012, 05:52 PM
Pony 5.0
Pony 5.0's Avatar
Thanks. Makes perfect sense. It's a Ford cable with a Steeda quadrant. Time to climb under the beast.
Pony 5.0 is offline
Old 02-16-2012, 07:06 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
If it is a stock ford cable, I don't understand how you will adjust it from under the car.
TrimDrip is offline
Old 03-03-2012, 08:51 PM
Jfsram
Jfsram's Avatar
Crawling under the car will not tell you much. To confirm MJR's diagnoisis. Jack up rear wheels. Run the engine. With the clutch pedal to the floor and the transmission in gear. Rear wheels should not be turning.
Does your clutch pedal engage the clutch right off the carpet? Should be about 1/2 way up.
Jfsram is offline
Thunderball
15
11-22-2015 11:49 PM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
Mustangmalo
09-06-2015 05:22 PM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: T5-Z wont shift when warm
