fuel pressure question
im installing a bbk adjustable fuel pressure regulator in a few days...i know the stock pressure is 39, is the 39 with the vacum line on or off? And also was wondering is there any power gains by bumping up the fuel pressure?
well there are power gains if your starving for fuel, thats it.
39 doesnt sound like a good number, 36 with vac on, and 42 with vac off what ive always gone by
but i dont mess too much with FP
what kind of mods are you dealing with ?
right now i just have a trick flow upper and lower, 70mm throttle body, trick flow pulley's, cold air intake, sn-95 maf, headers, full exhaust w/no cats, electric fan, walbro 255....soon i will be adding gt-40 heads and 1.7 roller rockers
you can tweak a few ponies by lowering...but your walking a fence thats not very forgiving.
good score...you'll use it later
id do 42 psi with vac off and dyno tune it when all your mods are done. better to be phat than run lean
