clutch?
Old 02-22-2012, 08:46 PM
amlmustang
amlmustang's Avatar
Default clutch?
Ive got a 89 5.0 that im taking everything out of and putting into a 93 shell. Im also changing it to a 5 speed. Ive just about got everything for the t5 but i am missing the back up light harness and the four bolts that hold the transmission to the bellhousing. Was wondering if anyone knew where I could get those two parts? Also, Ive never owned a 5 speed before and was wondering which clutch would be best for me to get. Everything on the car is stock other than the off road x-pipe. Never bought a clutch so not sure what im looking for.
amlmustang is offline
Old 02-23-2012, 07:31 AM
Tony71502
Tony71502's Avatar
Get a stock clutch.
Look at latemodelresto for other parts.
Tony71502 is offline
Old 02-24-2012, 08:41 PM
torchred5.0
torchred5.0's Avatar
If I were you I would just buy a stock clutch from autOzone bc it has a lifetime warranty which comes in handy if you a rookie on a 5 speed...it isn't the best performance clutch but you will be able to swap it out if and when you burn it up...after you learn to drive stick good get yourself a king cobra or centerforce...good luck man
torchred5.0 is offline
Old 02-25-2012, 06:13 AM
AdderMk2
Banned
AdderMk2's Avatar
you can buy your missing bolts at your local hardware store. They should be 7/16"-14 and probably about 1.5-2" long.
AdderMk2 is offline
Old 02-26-2012, 02:02 AM
Tony71502
Tony71502's Avatar
Learn to drive stick on the bad clutch then upgrade it. That's what I did. Only takes about a week or so.
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
ccdguy
09-19-2015 05:20 PM
MasterLanMan
09-13-2015 08:21 PM
Quick Reply: clutch?
