how much power am i making?
i havnt dyno'd it or taken it to a drag strip yet. but could anyone ball park me where it would be at? its the same 302 it came with but has been bored .30 over. it had the following installed
Description Part #
SBF engine kit; 367 hp / 340 Lb/Ft of Torque with hydraulic flat tappet camshaft (based on 302cid) 2091
POWER PACKAGE TOP-END KIT #2091 367HP/340 LB-FT OF TORQUE INCLUDES:
Part No. Description
7122 Performer RPM Hydraulic Flat Tappet Cam & Lifters
60229 (2) Performer RPM Cylinder Heads, complete
6991 Timing Cover Gasket and Seal Set
7364 Cylinder Head Gasket Set
1405 600 cfm, square-flange, manual choke (non-EGR)
7521 RPM Air-Gap 302 Intake Manifold
8524 Intake Manifold Bolt Kit
8552 Cylinder Head Bolt Set
7820 Performer-Link Timing Set
also has msd distributer, new high tq starter and alternator, ford racing plug wires, aluminum radiator, shorty headers, bbk xpipe with cats, 2 1/2" flowmaster 40 exhaust, new 5spd trans with clutch, new 3.73 gears and new traclock. has the smog pump and ac stuff still on it. also has new firestone tires idk what size just 16" rims.... so with all this what am i putting down and also what kinda time should it run at the drag strip? i woruld like to take it this summer and see but need to work on my launch and shifting... i dont power shift and need to do it i was told.
Description Part #
Id say if everything is dialed in right it has the porential to be in the 280-310whp area and track times all depends on if your a good driver how much experience you have weight of the car and what tires you run... as of now street tires tires 13.0-13.50 on a drag radial or slicks 12.3-12.7.
They are some meaty firestones..... exact kind idk..... and the exhaust isnt a flowmaster. That what the guy told me but i was underthere today because one of the heat sheilds on cat was making noise so i jb welded it. And its a magnaflow exhaust... real nice shiny looking mufflers and pipes and 3 or 4" tips.... i have a exhaust clip i shot thismorning and will put it on as soon as i have time to upload....
Also im fairly good at shifting it but i could use a short throw with a rod that moves it back a few inches before i go racing... sometimes i grind 3rd n 5th because it not all the way in gear because i need to sit all the way back.... i feel like a giant in it sometimes 6'3" 225lbs
Diode Dynamics
28
05-26-2022 12:02 PM
ShaneB26154
35
03-04-2021 04:05 AM
YoungStangsMan
09-05-2015 07:01 PM
jpplaw
08-22-2015 09:29 PM
