331 or 347 stroker?
Old 05-01-2012, 07:56 PM
mxbadboy03
mxbadboy03's Avatar
Default 331 or 347 stroker?
which one to build? looking at going with 11:1 compression going to me all motor no power adders going to be drove on the street and strip some
mxbadboy03 is offline
Old 05-01-2012, 08:18 PM
mxbadboy03
mxbadboy03's Avatar
well the scat kit is actually 332 but i do know for sure im going with a scat kit
Old 05-01-2012, 09:38 PM
motorman524
MF Informant
motorman524's Avatar
I went with a 347. Find some TW 190 FACs or ported TW CNC 185s milled to 58cc with a custom cam and a Super Vic intake. That's what I did. You won't be disappointed.
motorman524 is offline
Old 05-02-2012, 07:20 AM
foxstang302
foxstang302's Avatar
I will also be going with a 347 tfs170 heads (already have them) and a custom cam.
foxstang302 is offline
Old 05-02-2012, 08:23 AM
Moonshine
Moonshine's Avatar
331 will be a way better setup if you're not building a straight race engine. Rod angle on the 347 is pretty extreme.
Can rev a 331 to the moon too!
Moonshine is offline
Old 05-02-2012, 10:46 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
oh dear...the ole R/R debate again........a 331 is not a way better set up, you need to stop reading magazine hoopla/articles........for one a 331 and a 347 built right , perform equally as well number 2 there are far worse rod angles out there found on other engines that have gone 100k + such as the ole SBC 454 and iirc the ford I-6 300, CARE TO KNOW THE R/R on those motors vs a 347?? and you can rev a 347 to the moon as well, heck I run a 347 that doesn't burn oil nor has any R/R ISSUES, been running it for 4 years, got a friend as well who has a 100k on his 347 and uses it for a courier service, and no issues. this topic has been debated time and time again and floats around magazie article claims with the so called theroy and no real life examples, FYI a347 can be built more than 1 way...5.315 rod or 5.4 rod...to each his own
here's some food for thought, become a member and read the R/R debate.
http://sbftech.com/index.php/topic,6087.0.html
mjr46 is offline
Old 05-02-2012, 01:32 PM
mattdel
mattdel's Avatar
No replacement for displacement, as they say. Not so true anymore with variable cam timing engines and whatnot, but for good 'ol american V8 power, bigger is better, IMO.
mattdel is offline
Old 05-02-2012, 05:56 PM
motorman524
MF Informant
I've revved mine WAY past the 7k mark plenty of times... 347s are very streetable and reliable and can make loads of powah when built right. Which means no cost cutting!
Old 05-02-2012, 06:53 PM
mxbadboy03
mxbadboy03's Avatar
guess 347 it will be then i believe the scat kits run the 5.4 rod and i by no mean pound on 1 all the time i drive my stock 5.0 like a granny lol might get on it once a ween in 1st and 2nd to blow the smoke out looking to get about 400 whp leaving the efi tho looking at probly a 580+ lift cam ty[e r trick flow intake 75 or 80 mm tb and have changed plain to go 10.5.1 compression and a good set of aluminum heads and roller rocker arms anyone got any thoughts on my parts? also intake will be ported and polished to make the heads no egr no cat's
uedlose
The Racers Bench
10-01-2015 08:31 PM
Brett Ludlow
09-23-2015 06:59 AM
EASTIDEE123
09-15-2015 11:08 AM
EASTIDEE123
09-14-2015 03:52 PM
YoungStangsMan
09-05-2015 07:01 PM
Quick Reply: 331 or 347 stroker?
