going to the track tonight...
Old 05-13-2012, 08:03 PM
  #21
majohns
majohns's Avatar
my dad has a service truck with his job. so i have an air compressor and all tools with me. back when i built my s10 with the 327, we did a 15-20min. starter swap in the parking lot, so the truck is handy.
majohns is offline
Old 05-17-2012, 05:53 PM
  #22
Venomantidote95
Venomantidote95's Avatar
It dosent matter manual or auto you dont have the power for slicks!!!!
Venomantidote95 is offline
Old 05-17-2012, 07:55 PM
  #23
majohns
majohns's Avatar
so ultimately what is the difference between DR's and slicks? they are both designed for traction with no wheel spin one is designed for street use the other designed for track use. if both are supposed to hook when whats the difference?
majohns is offline
Old 05-20-2012, 04:31 PM
  #24
majohns
majohns's Avatar
there seem to be a few people telling me to go drag radials in stead of slicks but none of them can explain why other than i can use them on the road, which i care nothing about. so could someone explain how much HP you have to have to run slicks and what is the difference in the 2?
majohns is offline
Old 05-20-2012, 10:31 PM
  #25
TrimDrip
FudgeDrip
TrimDrip's Avatar
I wouldn't put them on until you put it on the bottle. Example: This is a friend of mine's 450+ hp car.
http://www.youtube.com/watch?v=3uXWFeJaLsY
When he put slicks on, he slowed down.
TrimDrip is offline
Old 05-26-2012, 05:32 AM
  #26
uedlose
uedlose's Avatar
If it was me I would run the MT/ETstreet that are NOT the radial. Why I have seen to many heavy stick cars just not work with a drag radial start adding power to it and it gets even worst. I have seen many friends go down that road. get the the non D/R ones in a 26in tall and unhook the front sway bar if you still have one air them to around 15psi. for a start and have at it.
One reason I can think you may slow down with a full slick is lack of power a lower power car seems to like to slip the tire a bit and that helps keep the bog out of it and gives a false running start. Tell you another thing slicks and sticks and stock axles dont work very long seen that also to many times it is not if they brake it is when but the ET street Non D/R will brake a axle also but not as bad as a slick.
Now if it was a auto I would say run the D/R all day. By the way the D/R are not that bad in the rain I have been caught out a few times really not bad at all. now the ET Street non D/R are awful I have been stuck on a large hill in a big downpour I could not go up the hill and yes I was on the street
uedlose is offline
Old 05-26-2012, 12:39 PM
  #27
majohns
majohns's Avatar
these the ones you talking about? http://www.summitracing.com/parts/MTT-3743/
majohns is offline
Old 05-26-2012, 04:16 PM
  #28
uedlose
uedlose's Avatar
that is the ones
uedlose is offline
Old 05-26-2012, 04:20 PM
  #29
89LX Coupe
89LX Coupe's Avatar
I personally prefer the et street slicks for track use. Main reason being I've has my drivetrain parts last longer since the side wall takes the shock out the launch. I can get way more aggressive on the launch and not have to slip the clutch none. I've been on my bolt on set up on 253whpthe with the stock 3.08 gears axles and posi on a 27x11.5 hoosier qtp launching off the rev limiter even with bogging some I still ran over a tenth faster and 1mph fast in th1/8th mile.
On drag railas nittos's and the mickey Thomson's I have had bad clutch slipping, bent an axle, and completly exploded my alburn posi unit at the drag strip. Now I will say I'd rather run a drag radial on the street bc for me they seem to hook better and if you get caught in the rain you can still get where you need to go.
89LX Coupe is offline
Old 05-26-2012, 09:26 PM
  #30
TrimDrip
FudgeDrip
TrimDrip's Avatar
The thing is not many people will launch the car like that.
I have seen a few cars tear up getting out of the water box and hooking. That will cause some damage normally.
TrimDrip is offline
Quick Reply: going to the track tonight...
