hatchback problem
hatchback problem
I have a 91 gt 5.0, the latch on the hatchback doesn't latch all the way, only half of it closes. Can anyone tell me how to fix this? I am new to this site and just got this car so I'm going to try to fix it up to original stock condition.
Thank you for any help
I have never done a hatch but, I have done this to a many of trunks that wouldn't shut. It may not be the same problem so you may have to take everything off the hatch to see what the problem is.
Anyways, I would always adjust what the latch hooks to. My Mazda did this one time and I was in a hurry so I stuck a large prisebar in the thing and just bent it up. On customer cars I would take it loose and move it.
my hatch wouldnt latch properly or not at all sometimes. so i got some advise on here and it worked beautifully. either do one of the two or both. take your trim panel orr the cieling above back seats at the roof of the body near hatch. will be 2 bolts there. get a friend or someone to help you. loosen bolts slide one side foreward toward car a bit then do other side. try it. if all works good screw panel back up. if not at the striker latch take trim off around it on my 85 its just 2 screws and get a star head and loosed that and adjust that untill it closes right. if those dont work then idk man u might be up $hits creek.
Thank you for the reply. The two pieces that close around that striker bar you're talking about, that's what I'm having trouble with, but maybe if I mess around with it like you suggested... hopefully these will work.
Thanks again, April
Thanks again, April
does it still have a striker bushing? Its made of nylon and they tend to break with age. If its off, replace that first, any auto parts store will have them and they are cheap. If it's broke off your latch won't hit properly and can cause your problem
this^^^^^^^^^
Yes.... or just do some backyard customs on it..., all iv done is wrapped black electro tape around over the broken bushing.., this will let the latch on the hatch lock again on the "stem, striker etc.?"
Seanam
10-04-2015 10:15 AM
stangin1996gt
09-21-2015 11:01 AM
