What are some of the easiest and best ways to achieve decent weight reduction in a 95gt. Other than the a/c and smog. I know they're the heaviest 5.0s out there.
Spare tire, back seat, sway bars if your looking to run at the dragstrip. Theres alot more little things. Just depends on how crazy you want to get. Aluminum heads are quite a bit liter than stock. Lighter aftermarket wheels can be had with a little research. You should be able to pull out 150 pounds no problem.
Tubular front suspension, including sway bar. Aluminum flywheel. Shorter bolts and screws anywhere and everywhere. Fiberglass hood. Fabricate aluminum brackets to replace steel ones hither and yon. Smaller battery.
