my winter overhaul will need a new clutch. what should i get
ok so over this upcoming winter im taking my lousy 350rwhp fox and pushin her to her limit. with the curent upgrade I'm at 9.2-1 comp. here are the plans for the winter and i need help cause im not sure what i need for a clutch.
powerdyne superchercharger db11 with 12lb pulley
aluminum drive shaft
elec water pump
elec fan
batt relocation
shaved bay (for shows)
the curent tune is set for 89 octane with emisions. going straight pipe, egr delete. ac delete, and tuning it to run 100 octaine all day. if the math is corect i should be seeing around 530-550 rwhp. motor is already built for the supercharger with 42lb injectors. 80mm full intake with ported and polished upper and lower intake and heads. e303 cam, and much more. but now im desperate to find the right clutch and im loosing my mind thinking about out. can some one help me out.
elec water pump
elec fan
batt relocation
Im probably going to go with the center force. i saw it on jegs and it really looked like it would work out pretty well plus i saw a reveiw of some guy pushing 760rwhp and had it. hes been running it for 5 years and takes it out almost every day so im co.vinced. but thanks for the help
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
ccdguy
09-19-2015 05:20 PM
