wanting to build stroker need help with set up and choosing parts
Old 12-23-2012, 08:28 PM
Venomantidote95
Venomantidote95's Avatar
Originally Posted by Fordfoxbody88
okay my one friend has a 331 and said hes either pushing around 600 or 650, but he drag races with it to and has a stock 302 block. im not looking to make anything that crazy im just fine with 450 to 550 but it would be neat to have a s/c do you think it may be possible if i make it just a 331?
I would like to know your buddies tricks for that kinda power from a 31, but besides the point! you can get an excellent stroker kit from DSS racing for 880.00 right now good for about 550hp, cast nodualr crank, forged i-beam rods and forged pistons comes with rings and bearings also!
These kits are great pieces I have used a few of there kits in various cars, and they have always been top quality!
If you plan on going with boost later you would be safer by a slim margin going with the 331, use a main girdle with studs but once you pass a certain power with your given block it will break, but I have done a few stock block strokers that are still living under boost and nitrous, a good balance job and the correct assembly techniques and tolerances will help you on engine life!
All in all you can get to where you are going well under 7k if you can do most of the work yourself!
You can get a good low budget aluminum head for about 700, you can get a set of cnc`d 205 edelbrock E streets for 1150!
What do you plan on doing staying efi or going carbed?
Venomantidote95 is offline
Old 12-23-2012, 09:48 PM
83glx5.0
83glx5.0's Avatar
picked up a 347 stroker kit from this place.
http://www.fordstrokers.com/
Never got to install it, but their customer service was great in helping me figure out what I needed.
83glx5.0 is offline
Old 01-01-2013, 08:18 AM
MADMAC
MADMAC's Avatar
Good Honest people here. No short cuts on their work.
MADMAC is offline
Old 01-14-2013, 06:39 PM
89blackonblack
89blackonblack's Avatar
if you plan on putting boost to that stroker some day you have to go with a better block than stock. i would say once you get up over 500 hp on a stock block your starting to push it. if youre going through the trouble of building a motor now and you want to make big power with it i would invest in a block too.
89blackonblack is offline
inyadreems
08-21-2015 09:10 AM
Goldenpony
08-19-2015 08:46 PM
WDScott
08-17-2015 06:38 AM
WAstang2013
Wheels & Tires
08-12-2015 08:19 PM
Quick Reply: wanting to build stroker need help with set up and choosing parts
