Timing at 10 or 14 degrees?
Old 04-15-2013, 07:39 PM
StalkerGT
StalkerGT's Avatar
Default Timing at 10 or 14 degrees?
Is it a big difference running 14 degrees over 10? I don't do alot if highway driving so I prefer the power over gas mileage. Was just curious what the differences would be. I have stock heads and cam
StalkerGT is offline
Old 04-15-2013, 07:54 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I usually set them at / around 12-14 max, and if it pings, back it off a degree or two and run premium gas
mjr46 is offline
Old 04-15-2013, 08:05 PM
reldla1996
reldla1996's Avatar
Without a tune, your engine will make noticeably more power at 14, or whatever your car will tolerate. A tune will advance your timing, and they usually want the base timing at 10 degrees so they know how much the tune is advancing it over stock.
reldla1996 is offline
Old 04-15-2013, 10:44 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
well with advancing the timing you get more power and more MPG...as long as you keep your foot out of the gas you get more mpg lol
i run about 14 in my 5.0 with a t5 and auto trans mass air computer with 3.55 gears i dont get any pinging with 89
rmodel65 is offline
Old 04-16-2013, 04:46 AM
darkmach1
darkmach1's Avatar
16 base here, but I'm tuned on 93.
darkmach1 is offline
Old 04-16-2013, 04:50 AM
StalkerGT
StalkerGT's Avatar
Thanks for the replies...I set it at 14 and definitely noticed a difference in power! I always run 93 in it and I didn't get any pinging when I advanced it
Old 04-16-2013, 06:21 AM
9redfox3
9redfox3's Avatar
I got my stang set at 12 no pinging and run premium gas !
9redfox3 is offline
Old 04-16-2013, 08:24 AM
BabyGT
BabyGT's Avatar
I'm at 13 on premium, I haven't tried anything higher yet, was just gettin the car on the road
BabyGT is offline
Old 04-16-2013, 07:04 PM
nitrous_bob
nitrous_bob's Avatar
well yeah, you NEED 14* to compensate for the 93
what you need to figure out is if it runs the same at 12* with 87 octane. unless of course you wipe your butt with $100 bills...then leave it alone
i run 14* and 87 octane NA. i SPRAY 80 with 89 or 94 if its hot or cold, 89 if its under 80*
if its really cool ? i'll go 87 and 80 shot.
since octane reduces the combustability of the gas....you have to run higher timing just to get back where you were
nitrous_bob is offline
Old 04-16-2013, 08:03 PM
StalkerGT
StalkerGT's Avatar
Yeah I see what your saying...I will have to play around with it. The car isn't a daily driver so that's the only reason I only put 93 in it
Quick Reply: Timing at 10 or 14 degrees?
