Meanwhile 302 build. what do you guys think
I would go victor jr top end or trickflow. TF is really expensive though so maybe victor or afr. a good set of alum heads are going to cost aroung 1500. I mean you could also get some high flowing iron heads but you lose like 50lbs by switching to alum. as for a cam. custom grind. crower will hook you up with 1 for 350 and I put both my cars on it that it makes more power then the e cam
If I were only planning on using the stock type engine for maybe a year and a half I wouldn't spend any money on heads or a cam and just drive while I worked up my real bullet for the car.
I'd be inclined to do the 'big bore' 363 combo with about a 205cc intake on the head (inline valve) and some modern cam from Comps Cams......
