Power steering problem - MustangForums.com
Old 05-17-2013, 07:46 AM   #1
DennisC6
Default Power steering problem
Alright guys I need some help. I have a 1990 mustang gt. I just replaced the rack and pinion about a month or two ago and recently the power steering just stopped working one way but it would turn the other way just fine. So I thought it might be the pump so I replaced it and bled it. It worked for a little while then just stopped working again completely. I have also put a new belt and tensioner pulley on it.
DennisC6 is offline   Reply With Quote
Old 05-17-2013, 11:02 AM   #2
BabyGT
BabyGT's Avatar
Trash in one of the inlets on the rack blocking flow?
BabyGT is offline   Reply With Quote
Old 05-17-2013, 11:45 AM   #3
DennisC6
That could possibly be it. But it calls for type f tranny fluid and I didn't know that before so it had power steering in it for a while. Could that have messed anything up?
Old 05-17-2013, 12:53 PM   #4
BabyGT
BabyGT's Avatar
Same thing, but power steering fluid costs more. So, I would flush it all out, check for trash in fittings and lines, then add ATF like it calls for.
Old 05-17-2013, 12:57 PM   #5
mattdel
mattdel's Avatar
Return line problem, sounds like.
mattdel is offline   Reply With Quote
Old 05-17-2013, 01:45 PM   #6
DennisC6
How should I flush it out?
Old 05-17-2013, 08:41 PM   #7
mattdel
mattdel's Avatar
Don't worry about the flush just yet, it's not vital. Find the problem with the line. Will the wheels turn normally with key on/engine off?
Old 05-18-2013, 09:45 AM   #8
DennisC6
Yeah it's just hard as hell.
Old 05-19-2013, 10:29 AM   #9
DennisC6
I've checked all of the line and there is flow through all of them. Nothing clogged
Old 05-19-2013, 11:16 AM   #10
BabyGT
BabyGT's Avatar
You have something blocking flow somewhere, might be in the rack itself.
SE Michigan SN95 Urambo Tauro New Member Area 12 12-17-2016 04:30 PM
Steering rod knuckle bushing Cit95 New Member Area 5 09-22-2015 08:08 AM
Steering Wheel removal in 2005? kdryan 2005-2014 Mustangs 2 08-29-2015 10:57 PM
New member from Cali Tyoung68 New Member Area 7 08-25-2015 05:31 AM
Underhood Fuse #47 - Disaster waiting to happen jpplaw 4.6L V8 Technical Discussions 0 08-22-2015 10:29 PM
