Headlight Problem
Old 07-06-2013, 02:59 PM
Tha Boss
Tha Boss's Avatar
Default Headlight Problem
For some reason my headlights stopped turning on by the headlight switch. This happened all of a sudden one day. I press the button down and nothing happens. I bought a headlight swich thinking the buttons were shot. This also didnt work. So then i wired the lights up straight and they came on. Anybody else have this problem and what did u do to fix it?
Thanks
Tha Boss is offline
Old 07-06-2013, 06:38 PM
darkmach1
darkmach1's Avatar
Are the harnesses snapping on to the back of the headlight switch? I had an issue with mine where the harness was too short to snap into the switch when the switch was pulled out of the dash.
darkmach1 is offline
Old 07-07-2013, 05:55 AM
Tha Boss
Tha Boss's Avatar
Yes sir. The harness snaps on fine.
Tha Boss is offline
Old 07-07-2013, 05:58 AM
Tha Boss
Tha Boss's Avatar
Yes sir. The harness is on fine. The side marker lights work. The headlights jus dnt.
Tha Boss is offline
Old 07-07-2013, 06:36 AM
dawson1112
dawson1112's Avatar
Check the ends of the wires that go into the harness , some times the plug on the end gets brittle and pieces break off causing the connecting ends of the wires to slide out the back of the plug a bit when you push it onto the switch.
dawson1112 is offline
StalkerGT
11-28-2015 03:09 PM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
ccdguy
09-19-2015 05:20 PM
Mobiusone stang
09-07-2015 08:46 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: Headlight Problem
