Throttle Cable - MustangForums.com
Old 07-10-2013, 06:28 PM   #1
Redneck1465
Default Throttle Cable
I am in one of the last steps of my V6 to V8 swap but I need a throttle cable. My car is a 94. I have been looking online and I cant seem to find one on summit or similiar websites. Any ideas on where to get one would be nice. Or another car that has the same cable that I can pull it from in the junkyard would help too. Thanks guys.
Redneck1465 is offline   Reply With Quote
Old 07-13-2013, 12:07 AM   #2
Goosepoop302
Don't think your gunna get it off anything but a 94-95 stang if your trying a junkyard.. That is probably your best though
Goosepoop302 is offline   Reply With Quote
Old 07-13-2013, 06:14 AM   #3
dawson1112
Yea you have to get one from a 94-95 mustang 5.0 . there is no other car that had that same intake set up on it.
Late model restro don't even carry them that I could see on there web site, and they usually have every thing. So junk yard or ford dealer is probly you only course.
dawson1112 is online now   Reply With Quote
Old 07-13-2013, 09:04 AM   #4
Duncan_GT
Duncan_GT's Avatar
Did you do a fox tb conversion?
Duncan_GT is offline   Reply With Quote
Old 07-13-2013, 11:40 AM   #5
Redneck1465
A wrecked 94-95 mustang is basically out of the question. I have been looking for one for over 6 years and have yet to come across one. It is an explorer motor that is in the truck with the explorer upper and lower intake if that helps any. Just trying to find a way to get this thing going. I have yet to put the throttle body on so if there are ways around this I'd appreciate some ideas.
Old 07-13-2013, 11:41 AM   #6
Redneck1465
Oh and the part is discontinued at the ford dealership I already tried that route.
Old 07-13-2013, 12:17 PM   #7
Duncan_GT
Duncan_GT's Avatar
Quote:
Yes, there's a way around it. Since you have an Explorer 5.0, the upper intakes are the same style as the 86-93 Mustangs. The 94-95 models have a different style. So, you can either spend $100 for a throttle body adapter elbow (Trickflow and Edelbrock sell them) and continue searching for the 94-95 throttle cable...
OR
You can stick with the explorer/fox style throttle body configuration. This will allow you to use a fox body throttle cable. Here's a link to the cable:
http://www.latemodelrestoration.com/...Throttle-Cable
I can send you a document I have that explains and outlines the swap. Just requires a little wire splicing for the TPS I believe. In my opinion, the foxes have the better setup. It really cleans up the engine bay and dealing with the passenger side valve cover is much easier. Supposedly it also helps with throttle response and idle
Old 07-13-2013, 01:24 PM   #8
mattdel
mattdel's Avatar
Or, you can use www.car-part.com and go through the hundreds of SN95's in the junkyards across the US.
mattdel is offline   Reply With Quote
Old 07-13-2013, 01:29 PM   #9
Duncan_GT
Duncan_GT's Avatar
Quote:
I didn't see an option for the throttle cable with this
Old 07-13-2013, 02:19 PM   #10
mattdel
mattdel's Avatar
Just contact the ones who have TB's and ask them about the cable.
Possible Clutch Issues..? Thunderball 4.6L (1996-2004 Modular) Mustang 15 11-23-2015 12:49 AM
extnesion for radio antenna to head unit kevsgt 2005-2014 Mustangs 5 10-09-2015 11:12 PM
Chassis wiggle when off throttle? UrS4 S197 Handling Section 10 10-03-2015 07:23 AM
04 Mach 460 system, Installed Aftermarket HU, No Highs/Tweeters breaking Audio/Visual Electronics 5 10-02-2015 02:27 PM
Street Action Tonight Explosive Street/Strip 17 10-02-2015 08:45 AM
