Which gears?
Old 03-31-2014, 11:49 AM
Dexter007
Dexter007's Avatar
Default Which gears?
I'm about to order some gears and I need a little help. Right now the car has 2:73 gears. If I go to 4:10 will that make it wind out on the highway or should I stick with 3:73?
Dexter007 is offline
Old 03-31-2014, 11:53 AM
dawson1112
dawson1112's Avatar
3.73 manual trans,,,
4.10 auto trans
dawson1112 is offline
Old 03-31-2014, 01:36 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
4.10's will be fine, hardly any difference between 3.73 vs 4.10 rpm wise if you plan to race it, don't fear the gear
mjr46 is offline
Old 03-31-2014, 01:58 PM
Roger Mabry
Roger Mabry's Avatar
Default What will car be used for?
Any higher numbered gears will cause higher rpms on the highway... the higher (larger numbers) the gears the more rpms to go 65 mph.
Tires size will also influence the rpms... larger diameter is less rpm at 65 ...
Roger Mabry is offline
Old 03-31-2014, 05:17 PM
Dexter007
Dexter007's Avatar
Originally Posted by dawson1112
3.73 manual trans,,, 4.10 auto trans
that's the answer I was looking for thank you
Old 03-31-2014, 06:49 PM
Roger Mabry
Default What you received was an "opinion"
Check out this calculator and figure it out using 3.73 and 4.10 -
I would start with your current 2.73's to prove the rpm you are seeing now.
http://www.ringpinion.com/Calculators/Calc_RPM.aspx
With stock sized 15" tires the diameter is 27.4:
2.73 at 65 mph is 1523 rpm
3.73 at 65 mph is 2081 rpm
4.10 at 65 mph is 2288 rpm
Unless you are going be "racing" this car - you will notice lower fuel mileage,
higher noise from the engine
I like my 2.73's as these little 302 HO's are not race cars, just nice drivers.
Having had gears up as high as 5.12 on the street with no OD, I do not like
the high cruising rpms - maybe with a six speed and a OD of .50 or so.....
Cruising around 2000 rpm is OK.... or 3.73's max = my "opinion"
Old 03-31-2014, 10:23 PM
mjr46
mjr46's Avatar
mjr46 is offline
Old 04-01-2014, 08:52 AM
Roger Mabry
Default Simulate each of the gears
Just drive the car in/out of OD, run it to 65 at each of the "new rpms" and
you can see what the car will sound like....
Old 04-01-2014, 10:10 AM
88 orangepeel notch
88 orangepeel notch's Avatar
I liked your answer mjr lol
I love these gear threads, just as much as I love my 3:55's, they're the best.
88 orangepeel notch is offline
Old 04-04-2014, 06:30 AM
9redfox3
9redfox3's Avatar
3.55's or 3.73's sound good for daily driver ?
9redfox3 is offline
Quick Reply: Which gears?
