New Guy and 1990 GT build up
Old 11-14-2014, 07:17 AM
  #91
JBeachstang11
JBeachstang11's Avatar
Originally Posted by mjr46
wanna buy a tremec 3550..lol, I'm gonna yank mine in the near future in favor of an A5 BUILD.......astro performance ftw!!!
Cool man!
Sure PM me about it. Thanks.
edit: Just noticed you're in WV, never mind lol..
JBeachstang11 is offline
Old 11-14-2014, 11:07 AM
  #92
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Originally Posted by JBeachstang11
Cool man!
no problem, it's not coming out for a while, no time......spend it all on customers rides..lol
mjr46 is offline
Old 11-22-2014, 09:07 AM
  #93
JBeachstang11
Alright, little update here.
- I made my starter grind/screech much better by forcing the starter towards the flywheel as I tightened the bolts. Makes a case for slottin the holes a small amount.
The car starts right up and will have the textbook surge for a couple mins so I have to hold the revs just around 1200-1500 with the throttle then it will idle fine. Almost like it passes a certain timeframe, 2mins or so, then will play nice.
The Borlas are awesome by the way.
Now driving is pretty good. I'm still not giving it WOT since I'm still <50mi on new engine.
Only issues are after revving 1st gear out (3.73) medium load 4500rpm then shifting into 2nd same load I will get a something like a miss. I just don't know if it is spark or fuel related.
Then nailing the brakes to bed in my pads sometimes the car would stall, that was with the a/c on though (which is working lovely ) - so the car not being dialed in that well coupled with a/c load..
I have the bottom few rows on my MAF table calibrated for the ProM 19# MAF to counter an overly rich idle, and then after that once rpm increases I have used the ProM24# table up to the 15.999v top
HEGOS are generally reading .5-.8 both sides while my WB still reads lean at times.
My ECT and ACT is still reading constant (20 and 100) in Bin Ed 2012 when I'm logging. Anyone have an idea on how to chase that? Don't those use the same lead in the harness?
Old 03-23-2015, 08:55 AM
  #94
JBeachstang11
Upate: Clocked the MAF to 6pm position and seemed to eliminate the surging and the 3000+rpm misfire. Car is very streetable so I am swapping out my 96cobras for some 17x9 03 cobras with 275 tires. Post a pic once swapped.
Latest run after MAF reclocking..
Old 03-24-2015, 07:22 AM
  #95
88 orangepeel notch
88 orangepeel notch's Avatar
I didn't get to watch the whole vid, or crank the volume as I'm at work. But sounded great to me, can't wait for spring.
Congrats
88 orangepeel notch is offline
Old 03-24-2015, 07:28 AM
  #96
JBeachstang11
Congrats
Thanks peel. Needs a little more drop up front. My strut brace is pushing my hood up at the moment.
Attached Thumbnails New Guy and 1990 GT build up-img_9619.jpg   New Guy and 1990 GT build up-img_9626.jpg
Old 03-25-2015, 12:45 PM
  #97
88 orangepeel notch
First, I'd save up so you can afford all 4 of the same rims lol.
Seriously though, looks great...
Old 03-25-2015, 01:07 PM
  #98
JBeachstang11
Hahaha! All 4 are 03 Cobras, just different side.. e
That would be pretty ghetto.....
Thanks man, reading through some of your threads, 5 spd swap thread
actually
Old 10-12-2015, 09:42 AM
  #99
JBeachstang11
Finally sourced a WC T5 for rebuild to swap out the Non-WC unit in there. Searching around for best place to order the kit from.
Also painted my engine bay to match
Old 10-12-2015, 12:09 PM
  #100
mjr46
mjr46's Avatar
astro performance
mjr46 is offline
Quick Reply: New Guy and 1990 GT build up
