306 HP Est.
Old 07-06-2014, 01:03 PM
65 Redfire
65 Redfire's Avatar
Default 306 HP Est.
Hi guys, new here to the forum. Just curious to see what you guys with 5.0 HO builds think my new combo will make to wheels or flywheel:
306 CI
TRW Forged pistons 9:5
Home ported E7TE with stock valves
TFS Stage 1 cam
Edelebrock Air Gap Intake
Holley 750 vacuum secondary (only odd part being to big but it was free!)
Electric Fan
BBK under drive pulleys
1 5/8 long tube headers with dual 40 series flowmaster
Rebuilt c4 with BTE valve body and stock boss hog converter
Duraspark Ignition
MSD Blaster 2 coil
Holley 110 gph mech. fuel pump
The car that this setup is in is a 1965 Mustang with 3.27 gears. Also any idea of 1/4 mile times? Drag strip would be at 20 ft above sea level and of coarse temp less then 65. Any info appreciated!
65 Redfire is offline
Old 07-06-2014, 02:20 PM
bluebeastsrt
bluebeastsrt's Avatar
280WHP and I'd bet it'll run low to mid 12s@107-109. The stock heads are your choke point on your build.
bluebeastsrt is offline
Old 07-06-2014, 02:29 PM
65 Redfire
65 Redfire's Avatar
Thanks for your estimate! Would have went with better heads and better carb (600-650 dp) if where not for $$$. This motor was built just to get the project rolling. Later on I plan to build a 331 or 347!
Old 07-06-2014, 06:50 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I doubt it'll meeet those expectations........I had a 66 coupe that I did a t-5 conversion to, had srp flat tops with D00e heads with 1.94/1.55 valves,crane fire ball 300 cam .500/.500 lift , ported heads, roller rockers, rpm air gap, 650 dp, and hooker super comp 1 5/8's headers, duraspark ignition, and 3.50 rear gears with Hd yukon trac-loc and on street tires it ran 13.3's at 104-105 mph, this car had drum brakes all the way around and stock suspension......with slicks and better gears, I'm sure it could of hit 12.90's but the brakes and suspension would of needed attention.........so my set up was a little more aggressive than the OP'S and his has a c-4 so it'll rob some power there. I'd guess mid to high 13's
mjr46 is offline
Old 07-06-2014, 07:37 PM
bluebeastsrt
I have no idea what a boss hog converter is. But i have found a stalled auto is worth anywhere from .5 to 1 second depending on power level. So I was actually giving him extra credit if he has a stalled auto. After thinking about it your trap speeds are probably closer. My 5.0 did 12.1@109 N/A. I probably had alot more suspension and power than the Op. If hes just running a stock stall C4 I would be inclined to agree with your guess. Im just to lazy to look up boss hog LOL.
Old 07-06-2014, 08:53 PM
mjr46
mjr46's Avatar
apparantly the chebby guys are none to pleased with Boss HOGG.......Time to call in Bo and Luke......lol interesting read here:
http://www.thirdgen.org/techboard/af...ters-junk.html
mjr46 is offline
Old 07-06-2014, 09:59 PM
bluebeastsrt
probably explains why I never heard of them.
Old 07-06-2014, 11:38 PM
tinman
tinman's Avatar
The gears are what is really going to kill this car.
I'm thinking low 14's on the best day.
BTW, heads should have a good 3 angle valve job, it really does add to the flow.
IMHO a 750 vacuum secondary really isn't too big for this engine as the engine will only pull what it can.
tinman is offline
Old 07-07-2014, 10:52 AM
88 orangepeel notch
88 orangepeel notch's Avatar
I'm gonna agree with tin on this one, being the cars not set up yet. Those gears and stock stall won't help your 60 much, and home ported E7's could mean good or bad results.
Here's my opinion with street tires:
2.2 60ft, 13.8 at 102 / 103
Are you going to the track soon to find out?
88 orangepeel notch is offline
Old 07-07-2014, 02:57 PM
65 Redfire
65 Redfire's Avatar
Thanks for the estimates guys! To be honest with you all my guess would be 14.3-14.7 at 96-98 mph and around 285-290 hp at flywheel and around 240 rwhp. Thinking about bringing it to the track in January or February 2015. If I would go now in the heat I would be lucky to run in the 14 sec zone.
Quick Reply: 306 HP Est.
