Add this one to my list of mustangs .
Here it is , needs a little work on the front clip and I have to pull the trans and rebuild the synchros in it. But other than that its in pretty good condition. Has a lot of stuff done to it mostly suspension and supposedly an E cam. Maf conversion and pretty much stock crap for now.
The suspension has the Eibach Pro-Damper kit #3514.840 , Moser C-Clip eliminators.
Also Has Yukon gear and axle kit for 31 spline axles, 3.73 gears 8.8 rear.
Frame is tied in, with tubular upper/lower control arms.
A/M corbra R staggered wheels
245/45ZR17 in the front
275/40zR17 in the back.
Drilled slotted rotors
And Possibly some other stuff Ill find when I dig in a little.
Congrats, a notch with black Cobra R's, I knew you wanted to be like me lol. Now, orange that coupe up and enjoy.
Seriously though, looks like a good start with the mods from PO. What's first on your list?
Im not sure Im even gonna mess with the engine much at all, I got a tremec out of a 2002 v6 that I am going to swap out the intake shaft , and tail housing for the one that's in it. The trans is really in bad shape, and grinds in just about all the gears. Was going to order a rebuild kit but I got a steal on the 02 t5 for 300 bucks. It came out of a wrecked 02 v6 with less than 50k miles on it. Ill get that swap done this week some time, if I can ever get time away from working on my sisters car, and my moms car.
Need to get the front bumper cover off, fix a small hole that is in the corner of it , prep it for paint . I have a fender extension ordered for the right side fender , and need to get the front fender brackets straightened out so every thing lines up on the front end.
Ill probly just get it looking good and shifting proper and then pass it along to someone with a bigger billfold than mine. lol
Up here I should have no problems getting 5-6k for that car, I should only have about 3800 total into it before I sell it . There is no rust on it other than minor surface rust under the lip of the deck lid.
