View Poll Results: Foxbody, SN95 (only the 5.0), or Notchback
Fox
14.29%
Sn95
42.86%
Notch
42.86%
Voters: 7. You may not vote on this poll
Foxbody, SN95 (5.0 model only), or Notchback
Which is the easiest to modify and build to corner and go faster
only reason for the fox and notch separate is the weight distribution and what not and I would like a few opinions on these cars
I don't think it matters. None of theses cars are known for handling. Fox is lighter. SN95 is a little more modern but to make either handle you'll have to gut the suspension and go full aftermarket. Coilovers, adjustable dampers, solid bushings etc.
A fox (notch or hatch) is an aerodynamic brick. Take that with a grain of salt. You'd be better off using a newer model for autocross purposes, unless a complete suspension overhaul is your cup-o-tea.
In terms of straight line drag, my vote is to the notch.
mrappe
09-26-2015 10:16 AM
