331 stroker with reverse dome pistons
Old 04-23-2015, 08:24 PM
colonjavier1
colonjavier1's Avatar
Default 331 stroker with reverse dome pistons
I just bought a 331 stroked block with reverse dome piston. I'm looking to use performer RPM 2.02. I was wondering if installing the F303 cam would be good with piston to valve clearance
colonjavier1 is offline
Old 04-23-2015, 08:59 PM
bluebeastsrt
bluebeastsrt's Avatar
You have to measure PV clearance reguardless of what every new cam you use. I'd go with a better cam than what you mentioned. Custom grind is best. Also measure for correct push rod lenth now that your changing valve train geometry. Good luck.
bluebeastsrt is offline
Old 04-24-2015, 10:56 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
lol...302 parts on a stroker........if you want an off the shelf cam, comp has the xfi series designed for stroker applications or better yet.....email this guy and non other : www.flowtechinduction.com Also, do a little more research on head choice......if the eddy rpms are a 170cc intake runner head you have choose........you'd be wise to look into a larger volume runner head for a well built stroker......min 185 and even better a 205 head
mjr46 is offline
Old 04-24-2015, 12:47 PM
colonjavier1
What head do you recommend?
Old 04-24-2015, 12:49 PM
colonjavier1
Patriot performance head with 60cc chambers 2.02 intake/1.60 excaust
Old 04-24-2015, 01:12 PM
bluebeastsrt
I recommend trick flow twisted wedge 11R 205cc series heads. If your on a tighter budget you can go with TF 190cc fast as cast heads. I have the 190s on my 363 stroker. They flow very well for a 190 head.
Old 04-24-2015, 03:02 PM
colonjavier1
I'm also going to add a vortex have charger that I have would that all work
Old 04-24-2015, 03:53 PM
mjr46
mjr46's Avatar
stroker + stock block + boost= bad idea.....unless you keep the boost at a min 8-10 psi have the tune on and keep rpm under 6500, then it'll live for a decent while.....but still a gamble
mjr46 is offline
Old 04-24-2015, 08:56 PM
colonjavier1
AFR-1492 185cc 60cc 2.02/1.60 outlaw street heads. This be perfect then.
Old 04-24-2015, 09:50 PM
mjr46
mjr46's Avatar
not bad choice
mjr46 is offline
Quick Reply: 331 stroker with reverse dome pistons
