Strut Tower Brace
Strut Tower Brace
I am considering installing the Ford Strut Tower Brace. I have a GT Premium, non PP. I read on another forum that there is no need to install the cowl brace because the stock is identical (non PP). Is that true?
Tower Brace
I read in another forum that if you have the Performance Package, you have a metal firewall brace installed. If you don't have the PP, you have a plastic brace that should be installed with the strut brace to get the real benefit.
Here is a post with picture showing both, if you plan on a rear intake supercharger like the Roush, don't bother with the long one, cause watching the losers on "the Power Block" on Spike Tv, they cut off the drivers side to make room for the blower intake.
This is the STB that matters not that silly thing going over the engine. If your car was a PP it will have the long steel on in the picture if it doesn't have that it has the short plastic one. Put the long steel on on FIRST. Then buy the cosmetic one of course having it functional might not matter to you.
09-16-2015 07:53 PM
