2015 GT 5.0 knocking at start-up?
10-19-2015, 01:17 PM
I have a 2015 GT that makes a loud knocking-ticking-rattling noise at startup anybody else? What was the cause?
10-19-2015, 02:57 PM
for how long? if it's just brief, it may be that the timing chain tensioner (hydraulic, uses engine oil pressure) has to pump up.
10-19-2015, 03:46 PM
What gas grade are you using? What grade did you have in it prior to the knocking?
10-19-2015, 03:53 PM
Quote:
Originally Posted by
jz78817
It does it at startup until the it idles down, maybe 15-25 seconds.
10-19-2015, 03:54 PM
Spork3245
Has always had Premium gas from Chevron.
10-19-2015, 07:27 PM
can you get a recording or video? phone should be adequate.
10-19-2015, 07:28 PM
dealer item should be under warrantee
10-20-2015, 03:46 AM
I'd get into a dealer! If it is low in the engine & dull knocking you could be losing a a main or rod bearing! I had one go out in a Ford V8 in the first 300 miles! Ford service laughed & smiled until I started it up & then said OH ****! New engine! Good luck!
11-23-2015, 10:23 AM
Dealer says the Resonator coming apart inside, there is a TSB on it. Ordering the part will let you know if that fixes it.
01-12-2016, 04:46 PM
mdougals
All Fixed.
Stang5v0
10-15-2015 10:19 AM
ushiee
10-07-2015 09:51 AM
MustangV6P
09-28-2015 11:00 PM
DtRockstar1
Mustang Videos
09-27-2015 07:46 PM
mungodrums
09-22-2015 08:36 PM
