Check Engine light for 4th time in first 5k miles. #8 Cylinder each time.
Old 02-23-2017, 06:36 PM
KillverCity
KillverCity's Avatar
Default Check Engine light for 4th time in first 5k miles. #8 Cylinder each time.
The car is bone stock. No issues for first 3k miles. Then under normal cruising speed of about 35 with low RPMs my check engine light pops on.
Each time I take it in, they run a relative compression test, EEC test, and check the injectors. Each time they say everything is fine. I usually get about 80 miles on the car before the check engine light returns. I am not experiencing anything performance-wise. No trouble on startup.
The third time I had it in, they swapped the components from cylinder 8, with cylinder 7. They drove it for about 70 miles and the same code trips. "P0308".
They decide it must be the injector. Replace injector.
Got it back on Monday, check engine light by Wednesday. This is my 4th time with it back to the dealership in 3 months.
Anyone else experience this?
KillverCity is offline
Old 02-23-2017, 09:13 PM
Moderator
JimC's Avatar
Ask them to run the crank relearn process if they haven't done it. Maybe something got "lost" in the program.
JimC is offline
Old 02-23-2017, 11:42 PM
socal57chevy
socal57chevy's Avatar
What are the results of their compression tests? "Good" is not an acceptable answer...ask for specifics.
socal57chevy is offline
Old 02-24-2017, 05:07 AM
darkmach1
darkmach1's Avatar
Time to start looking into lemon law bro
darkmach1 is offline
Old 02-24-2017, 08:57 AM
redass02gt
EXTREME Moderation
redass02gt's Avatar
Try a different dealership if possible. This one clearly doesn't have an ace mechanic to turn to for tough problems.
redass02gt is offline
Old 02-24-2017, 01:06 PM
barstowpo
barstowpo's Avatar
Coil or plug? Intermittent coil problems are difficult to trace. That must be why they swapped stuff.
barstowpo is offline
Old 02-24-2017, 06:05 PM
KillverCity
Still waiting to hear back from Ford.
Yes the measurement they gave me for the compression test was "good". I will push for specifics.
Old 02-26-2017, 12:12 AM
socal57chevy
That usually means that they wrote on the back of the RO to get paid for the diagnostic time, but didn't actually do it. lol
I always write the results on the back of the RO and show the customer.
I've seen the Toyota 5.7 break a valve spring and the cylinder pressure will push the valve closed some of the time leading to a sporadic misfire on that cylinder. Sometimes it seals, sometimes it doesn't. If it isn't caught in time, it's just a matter of time before the piston smacks it and things get really ugly.
Weak coils can be hard to pin down, like barstowpo mentioned, but a lab scope will find a weak coil every time.
They need to put a different tech on your problem.
Old 02-27-2017, 06:52 PM
KillverCity
They just got back to me. They are saying they plan to replace the cylinder head.
Old 02-28-2017, 02:11 PM
movielover40
movielover40's Avatar
There you go.
If this doesn't work ask for another car.
movielover40 is offline
Quick Reply: Check Engine light for 4th time in first 5k miles. #8 Cylinder each time.
