Newbie mustang owner needs help with alignment
Old 03-16-2017, 02:34 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Next time you get it aligned, check to see the tie rod nuts are fastened to spec. Sounds like one or both sides aren't getting tightened down properly if the toe keeps getting jacked.
Derf00 is offline
Old 03-17-2017, 08:11 AM
Loue
Loue's Avatar
What would be the proper specs?
Loue is offline
Old 03-17-2017, 01:59 PM
Derf00
Gentleman's Relish
Derf00's Avatar
On 2005 to 2014 it's 41 ft/lbs. Not certain of 2015+ but I suspect it can't be much different. if anything 45 ft/lbs tops. You'll need a crows foot since you can't put a socket or box end on it though.
If I recall it's a standard size like 13/16"
Derf00 is offline
Old 03-17-2017, 03:01 PM
Loue
Loue's Avatar
Alright thanks I just got an alignment done Sunday I'll check it and see if it was torqued to spec
Loue is offline
