5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
How Hight you think she can rev
Old 05-26-2010, 09:06 PM
Paul1588
Paul1588's Avatar
Default How Hight you think she can rev
How high of an rpm can the 5.0 safely run at? is 8grand possible stock(minus a tune ofcourse) just curious
Paul1588 is offline
Old 05-26-2010, 09:11 PM
Lil_Chef
Lil_Chef's Avatar
apparantly with the future BOSS intake manifold in the works 8300 RPM is safe and accessible, which i think is AMAZING.
Lil_Chef is offline
Old 05-26-2010, 09:17 PM
Paul1588
Paul1588's Avatar
where did u read that
Paul1588 is offline
Old 05-26-2010, 09:20 PM
Gene K
Gene K's Avatar
I dont know how high the factory intake and cam will make power. Higher than the factory limiter at any rate.
Engineers claimed the bottom end was good for 8000 rpm at the intro but the cast (hypereutectic) pistons and factory rods would make me plenty nervous.
As stated the Boss R1 is turning 8300 rpm with a supposedly "stock" valvetrain.
Im planning on 7350/7500 for the soft/hard limiters when I get the tune but then I ran the 4.6L 3V limiter at 7250 rpm so Im used to playing with fire.
Gene K is offline
Old 05-26-2010, 09:33 PM
Paul1588
Paul1588's Avatar
only 7500? I thought a guy like u would be more ballsy ha
Paul1588 is offline
Old 05-26-2010, 11:32 PM
Driver72
Driver72's Avatar
unless it's making or holding power past 7000 rpm, there's little to no point. Even with a tune, it's doubtful you'll get meaningful power improvements above 7000 rpms. A dyno will answer that question for us all soon enough I'm sure.
Short of "holding the gear" for 1/4 mile runs if you are close to the stripe and don't want to make the shift or at a track and don't want to shift mid corner, there is no reason for extra revs if there isn't more power. If you are on the down slope of the power curve by more than a couple hundred rpms, all you are doing is slowing yourself down.
It's a different story with upgrades cams, headers, etc.
You will make more power in higher rpms then and it's an advantage.
Driver72 is offline
Nick Oliver
10-17-2018 04:22 AM
firehorse02
11-16-2015 11:28 AM
piotrek53
10-13-2015 06:54 PM
wraith777
09-28-2015 10:49 AM
Offendant
09-23-2015 07:21 PM
Quick Reply: How Hight you think she can rev
