2011 5.0L Clutch Pedal Issue Fix
If you have a clutch with the dual rebound springs. (Looks like a hybrid of the GT500 and GT 5.0 Setup pictured above) just remove the large spring by sliding the lower mount off the pin. You may have to work the pedal back and forth while prying on it as its under pressure. Ive already done this on my car and it does fix the problem. It does increase pedal effort from around 20 to 30-35 lb.
Below is a picture of the clutch side of the Hybrid Dual Rebound Spring on 4/26+ cars I believe.
Is Ford going to fix this?
Does anyone have any info on whether Ford is looking into this, ignoring it or trying to cover their @sses? I hope they fix it instead of going the cheap route and lowering the redline to 6,500 and claiming anyone operating the engine above this rpm is improperly operating or abusing their engines.
Ford, do the right thing, fix the issue, avoid scandal and earn more respect.
Gene- Thanks for the info. As of Friday, there were no TSB's for the '11's yet, I keep checking every few days. Mine shifts fine firing off quick shifts from first through fourth, I hope it stays that way.
They want to remove my entire clutch system (from pedal to flywheel) and replace it on my car including the new Job 2 Pedal Assembly. They want my complete system for testing. Im trying to decide if Im going to let them since the problem is solved.
I too have not seen anything on the TSB concerning this. I will ask the service shop if they have heard anything yet from Ford.
I dont mean to bring up an old thread but my car just started doing this today.
I got a bama Tune last week and i now shift the car around 7200 give or take.
Today this happened for the first time. I wanted to know if getting a GT500 pedal asse. will fix this completely or will i need the new pressure plate as well????
From 2011 Clutch issue thread
The clutch seemed to get stuck half way up and I had to push it down again.
Not Good...
Is there a TSB yet?
