5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
P-Zero's in cold weather
Old 01-02-2011, 07:08 PM
RickyBobby
RickyBobby's Avatar
Default P-Zero's in cold weather
Just a heads up, I have P-Zero's on my GT. Today the roads were clean and dry and the temp was about 29 degrees. I eased thru 1st and stood on 2nd, the tires broke loose at approx 4500 rpm in second gear!!! These P-Zero's don't like cold weather!! C'mon spring!
RickyBobby is offline
Old 01-02-2011, 07:21 PM
MrSandman
MrSandman's Avatar
Yep. The Brembo package tires are only rated to 40 degrees F... lots of fun @ 20 degrees!
MrSandman is offline
Old 01-02-2011, 11:13 PM
Nuke
Nuke's Avatar
Which model P-Zero? The last time I counted there were 10.
ANY high performance tire, even an all-season, will sacrifice cold weather handling due to the rubber compound that gives it it's high performance rating. Anything below 40 deg. F on a high performance tire and you need to drive relatively gingerly.
Nuke is offline
Old 01-02-2011, 11:19 PM
P Zero
P Zero's Avatar
For a second there I thought you were talking about me. And you're absolutely right, it's freakin cold up here man! 18 freakin degree's!
And yes, high performance tires + snow = bad day.
Do yourself and everyone else a favor and get some snows. You wouldn't wear your flip-lops in the snow would you?
P Zero is offline
Old 01-03-2011, 08:34 AM
RickyBobby
RickyBobby's Avatar
heheh, i usually keep it parked when it's cold, but I needed to take it for a spin (hadn't started it in a few weeks). It's ok if I behave, I was just being a douche.
Old 01-08-2011, 04:51 PM
95PreludeSi
95PreludeSi's Avatar
I've been really impressed with the p-zero tires that came on my deluxe gt 08, and now my base 2011 gt. They provide a nice balance in dry & wet conditions.
95PreludeSi is offline
Old 01-10-2011, 12:38 PM
wingless
wingless's Avatar
The poor traction equals increased rear brake wear.
wingless is offline
Old 01-11-2011, 12:25 PM
Dr_Gonzo
Dr_Gonzo's Avatar
The P-Zero Nero's on my GT and they do NOT like the cold either, especially before they have a few miles on them to warm them up. I have had a few occasions where the rear wheels broke loose @ around 50mph or so in 3rd gear under moderate acceleration. I've also noticed that they feel a little skiddish at high speed even after 40miles of driving. Taking it easy and keeping the limitaitons of these tires in cold weather in mind is definitely the order of the day.
Dr_Gonzo is offline
Old 01-11-2011, 12:49 PM
DarDan76
DarDan76's Avatar
Now that explains it, I thought it a little unusual that I chirp second gear with a six speed auto and very little throttle. Yes it is cold on the left coast to and really wet and the ice makes it exciting.
2011 5.0 GT Premium Grabber Blue
DarDan76 is offline
Old 01-11-2011, 03:27 PM
big red one
big red one's Avatar
Guys i realise this is a Tire review in the Uk can there is a very interesting tire test on the link below that compares the P zero to other well known brands
http://www.autoexpress.co.uk/product...tyre_test.html
Ian
big red one is offline
Quick Reply: P-Zero's in cold weather
