Dash rattle driving me bonkers
My 2011 GT has a rattle in the gage cluster. It sounds like a screw of something loose, but only when the car is cold, and only when hitting bumps. When it warms, I stop hearing it. Anyone dealing with this?
Mine has absolutely no rattle at all. My car was built on the 10th of July, 2010. I have over 6500 miles on the ODO. No rattles whatsoever.
Take it in since your car is not even one month old yet. Tell the dealership you have an annoying rattle and they need to fix the gremlin, even as small of an annoyance it is. No brand new car that is under 1 month old should have such a flaw, even though it is only a very small problem.
If I take it in, will I need to re-flash the ECU to stock? If I do, then I will need to put the stock air box on as well to prevent it running lien. Do they normally run codes on every visit, or will they just address the rattle?
They can only deny your warranty if they first PROVE the aftermarket stuff caused the failure. And a rattle in the dash is impossible to be caused by a custom tune.
If they say your warranty is void, tell them that is illegal and call Ford Customer Care and file a formal complaint against the dealership for taking an illegal action.
If they deny you any service, force them to prove the custom tune caused the rattle.
But to avoid even all of this, when you take the car in, tell them only about the rattle. Do not volunteer the info that you have a custom tune; just don't even mention the tune at all.
Almost 6000 and no rattle. Actually of all the mustangs I have owned, this one seems to have the quietest interior- other than the motor pipe. That may be why Ford piped the motor sound in- to hide rattles and squeaks! lol
