hellion turbo for the 2011 5.0 released
i' ll be all over this as soon as i see some results
Complete System Price - $5,995.00
Need more power from your new Mustang? Hellion has released its single turbo system for the 2011 Mustang GT. The completely stainless steel turbo system installs easily with no modifications and is sent 100 percent complete—including ECU re-calibration. The system can be supplied with a 64mm up to a 78 mm turbo. A 6 psi base setting will make over 600 hp, and the system is capable of 950hp—try that with a twin-screw! Call Hellion today for maximum performance.
System Includes:
- Turbonetics billet 64 mm turbo
- All stainless steel construction (lifetime warranty)
- Turbosmart Wastegate
- Hand held tuner with program
- 52 lb injectors
System Options
Ball bearing upgrade for Hellion/Turbonetics
$395
76mm Turbonetics Turbo $495
76mm Precision Turbo HPS
$750
76mm Precision HPA (ball bearing)
$820
Turbosmart boost TEE manual boost controller
$80
Turbosmart E boost 2 boost controller $539.99
Turbosmart E boost Street boost controller
$314.99
AEM wide band O2 kit $220
2011_front1 by blackmelissa15, on Flickr
2011_gt2 by blackmelissa15, on Flickr
System Includes:
- 52 lb injectors
System Options
$395
$750
$820
$80
$314.99
Umm, I think those are things you should do regardless....
I think Hellion is a great company, this just looked like a curious setup to me.
I too am wondering about the exhaust, is there anyway to get a snap shot of the manifold/down pipe setup? I know this could probably "leak" the design but would be helpful for inquiring buyers. Thanks
