modded 2011 GT problems
you can actually run the Steeda CAI + LT headers w/o a tune. The ECU will correct for it (I wouldn't drag race it like that, but its easily driveable) I ran my Steeda CAI w/o a tune for about a week.. they didn't have tunes for the 2012 when I ordered it so they had to just adjust a 2011 tune to get it to work on the 2012, it took some time to get it because the assumed i had a 2011 (I ordered my 2012 the day they switched over to the 2012 orders, I have one of the earliest made)
anyway, try just going back to stock tune.
also i was gonna make a similiar comment about the crocs as others did. too late.
if it seems to run on the stock tune order an e-mail tune and an SCT if you dont have one from American Muscle or Lethal performance or brenspeed or Livernois their tunes are all fine. I'm planning on getting a Livernois tune when I order a Boss Intake and O/R X pipe, they have the fastest 5.0s running their e-mail tunes, not even dyno'd hah.
You've got a wiring harness problem. A wire is shorted or broken somewhere, or a connector is loose. Check the plug in the trunk that hooks up the fuel pump. This isn't a tune issue, it's a "no fuel" issue or a "no spark" issue.
I highly suggest you buy a handheld tuner. Not being able to revert back to stock can lead to a major headache.
I agree. It is either getting no fuel or is flooded. It remindes me of the flooding issue in my mazda since you said that it occationally starts. I had to put a kill switch in to burn out all the fuel to prevent that. But hopefully once you have the ECU re-tuned all your problems will be taken care of.
we had the car towed today to the dealership to see if they could tell us if its for sure a tune problem. maybe they can flash it back to stock ? also we both understand that tuning can void a warranty, but we just want to get the problem solved.
