Here is the purge mount bracket: HERE
You will also need some hose to go from the purge line behind the throttle body on the manifold to the purge valve.
That is only for the 2011s, the 2012s are setup for the boss intake already, dont need any of that.
O_o, where did you see this? That kit is the same vacuum and purge lines that come with the Boss 302. Technically you don't need any of it, except for a bit of extra hose.
