Rear end whine after LCAs, 3rd link, panhard, and aluminum DS
#21
Yes, the DS came with CV joints on both ends. Anything's possible, but the whine is only heard upon deceleration while in gear -- would that point to the driveshaft? While accelerating, there's no whine and no noise coming from the rear. It really sounds like the rear end is connected to the chassis of the car via some metal, and the sounds I hear are being transmitted via that link and not dampened properly like when I had the stock parts in there with the soft rubber bushings.
The DS came with a new pinion flange, but can't see how we could have messed that up -- we removed the pinion nut, pulled off the old flange, installed the new flange, tightened the nut all the way, then backed it off, applied thread locker, and finally torqued to ~ 140 ft-lbs.
I'll double-check the pinion flange/rear end angle versus the transmission angle to make sure they're parallel -- I read somewhere they should be the same angle, usually parallel with the ground. So either the angles are off, or something was over-tightened, or the gears are just noisy during in-gear deceleration. I need to spend some more time under my car
#23
Perhaps someone with personal experience will chime in, but I've seen this discussed in other threads and it doesn't sound abnormal. I believe that your suspicions are correct and there is just more noise being transferred through the suspension components into the cabin.
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
92 5.0stang
08-13-2015 06:46 AM
