How to determine whether a pre-owned 5.0 GT has 3.73 gears?
11-19-2011, 12:18 PM
Just curious, its there a way to determine, either through the VIN or otherwise, whether a pre-owned 5.0 GT has 3.73 gears?
The 3.73s are a must have for me, and while I'll probably order new, I'm considering buying pre-owned if I can find a deal.
TIA
11-19-2011, 12:23 PM
It should say on the drivers side door jam. Unless the previous owner had the gears changed.
11-19-2011, 12:26 PM
Quote:
Originally Posted by
2012StangMan
Is there an option # or code, or does it actually say 3.73?
11-19-2011, 01:39 PM
Ford has a VIN checker. You put in the URL and the end of the URL is your VIN.....you can print the window sticker!
11-19-2011, 01:43 PM
General Jack
TIA
Here's that link, place the full VIN after the = sign to see the original window sticker.
http://services.forddirect.fordvehic...icker.pdf?vin=
11-19-2011, 01:57 PM
11-19-2011, 05:29 PM
11-20-2011, 12:07 PM
They're all still new enough that the sticker on the pumpkin should still show what was installed. Unless the previous owner has replaced the gears and not updated the tag (most do, because it's right there), you'll know what gears you have.
This is what mine says:
12-04-2011, 10:23 PM
hawkeye18
Easiest way to tell
12-12-2011, 12:30 PM
You can tell what it came from the factory with by the code in the door jam.
BB = 3.73 axle
KingRando
10-01-2015 11:16 AM
Darien
09-16-2015 09:30 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
vintageaion
09-08-2015 10:45 AM
5.0 kevo
09-03-2015 06:24 PM
2011 ,
2012 ,
373 ,
50 ,
code ,
determine ,
ford ,
forum ,
gear ,
gearing ,
gears ,
gt ,
mustang ,
sticker ,
window
