5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
here are my choices for my next upgrade, (suspension upgrades)
Old 12-04-2011, 10:01 PM
dominant1
dominant1's Avatar
Default here are my choices for my next upgrade, (suspension upgrades)
Eibach Pro Kit
http://www.americanmuscle.com/extrem...trol-arms.html
http://www.americanmuscle.com/frpp-g...ount-0512.html
http://www.americanmuscle.com/jm-panhard-0509.html
All For the low price of $1277.96... Not bad huh!!
dominant1 is offline
Old 12-04-2011, 10:20 PM
Pop's Stang
Pop's Stang's Avatar
I like your plan. You will improve the handling of your Mustang in so may ways. Good luck.
Pop's Stang is offline
Old 12-04-2011, 10:33 PM
Napoleon85
Napoleon85's Avatar
I'd probably go with the sportline, unless you're trying to maintain a soft ride. Same price, should perform a bit better but give up some ride quality.
Napoleon85 is offline
Old 12-05-2011, 12:01 AM
Syracuse315
Syracuse315's Avatar
There is a maximum motorsports coil-over kit for $1500 you should look at. Do you have FLSFCs yet?
Syracuse315 is offline
Old 12-05-2011, 09:15 AM
SteedaGus
Former Sponsor
SteedaGus's Avatar
Do you have a brembo brake equipped 2012? If so then the rear swaybar in that kit is the same as stock. Not an upgrade at all. Something to think about.
Your control arm choice will also have some NVH in street use. While a solid rotating joint on one end with a bushing on the other end is a good design to minimize bind, with only 1 bushing you have less noise isolation.
With bushings on both ends there is some bind, but its not excessive and noticeable for a high performance street application. In fact, control arms aren't really that critical if what you are looking for is handling anyway.
Why don't you give us a call so we can discuss what you really need and make sure you spend your money on parts that are actual upgrades while not compromising in certain areas like noise and vibration or getting you parts you don't really need for your goals.
SteedaGus is offline
Old 12-05-2011, 10:58 AM
Maraman
Maraman's Avatar
+1 I suggest you call or email Steeda, a little extra information couldn't hurt.
Maraman is offline
Old 12-05-2011, 06:08 PM
dominant1
dominant1's Avatar
Naa, i had the sportlines on my 2010 GT " to low" and rode to hard, I replaced them with the pro set before i sold it.
Sportline Pic my 2010 gt:
Pro pic my 2010 gt:
Old 12-05-2011, 06:11 PM
Napoleon85
Napoleon85's Avatar
Right ... they are focused on handling, versus ride comfort. Perhaps I didn't articulate that as well as I thought I did.
Old 12-05-2011, 06:29 PM
dominant1
dominant1's Avatar
My 2012 is a non brembo model...
PaulH2
20
01-31-2016 09:48 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: here are my choices for my next upgrade, (suspension upgrades)
