View Poll Results: Which 1 is best?
Voters: 6. You may not vote on this poll
Suspension choices which 1 to pick, here is my list!!
Roush 1.0 lateral grip set, the same kit used on the 5xr stage 2 mustangs.
This is a comprehensive Mustang suspension upgrade, and includes the following components:
Front Coil Springs
Rear Coil Springs
Front Struts
Rear Shocks
Front Stabilizer Bar and Hardware Kit
Rear Stabilizer Bar and Hardware Kit
Rear Jounce Bumpers
Recommended for use with ROUSH® 18-inch or 20-inch wheels
The same suspension used in 2011 ROUSH 5XR and Stage 2 Mustangs
Part #421156
Steeda spring sway bar kit and buy separate shocks and struts.
Steeda's Sport Spring & Swaybar Package is an excellent basic upgrade for your 2011+ Mustang that will greatly improve steering response, reduce body roll, and improve handling balance while maintaining excellent ride quality.
Includes our famous Steeda Sport Springs which lower the vehicle 1" in front and 1 1/4" in the rear along with a 2011+ Mustang specific swaybar package.
The adjustable tubular front swaybar of our package is 3 position adjustable and provides up to a 15% increase in roll stiffness. Our rear swaybar is a 1" solid bar with billet endlinks and urethane bushings providing a 25% increase in roll stiffness.
Package Includes
555-8216 - Steeda Sport Springs
555-1070 - Steeda Adjustable Front Swaybar
555-1057 - Steeda Rear Swaybar with Endlinks
Product Benefits
Cost effective upgrade
Greatly improves handling
Reduces body roll and improves steering response
Maintains great ride quality.
Eibach Pro set...
Complete Handling Package
Improves Driving Performance
Eliminates body roll; lowers center of gravity
Aggressive stance
Pro-Kit Springs included
Estimated Drop: 1.0" Front, 1.5" Rear
Fits 2011-2012 GT and V6
Ford Racing kit:
Track Car Handling. Lowering springs alone are fine to change the appearance of your Mustang, but if you want your GT to handle like a true track car you need to upgrade your entire suspension. The Ford Racing Handling Pack is a complete suspension upgrade kit to turn your Pony into a corner-carving machine.
Complete Kit. The Ford Racing Handling Package has everything you need. The kit includes a strut tower brace, front struts, rear shocks, lowering springs, front and rear sway bars.
Ford Racing Quality. When adding suspension parts to your Pony, trust the folks that know it best to provide top quality components that are made to out perform and out last the competition.
Application. This Ford Racing Handling Package is specifically tuned for use on the 2005 to 2012 GT coupe, it will not fit convertible models.
Kit Includes:
Front Struts
Rear Shocks
Lowering Springs with jounce stops
Front Sway Bar with bushings
Rear Sway Bar with bushings
Strut Tower Brace - does not clear 2007-2010 engine cover
Front Strut Mount Upgrade.
Front Coil Springs
Rear Coil Springs
Front Struts
Rear Shocks
Rear Jounce Bumpers
Part #421156
Package Includes
Product Benefits
Eibach Pro set...
Aggressive stance
Ford Racing kit:
Kit Includes:
Front Struts
Rear Shocks
None of the above if I HAD to choose...
I'd suggest the following:
Steeda Ultralite Springs ($230)
Koni STR.t Struts & Shocks ($400)
BMR Pan Hard bar ($125)
GT500 Strut Mounts ($85)
TOTAL = $840 + Alignment
Leave the stock sway bars alone (they are already the size people have been upgrading to for for years)
Also keep in mind that for stock size diameter tires the 1" drops are fine for most.....any lower diameter tires and your going to need at least 1.25" drop IMHO
Here is a video and actual testing showing what our suspension options will do for you from Muscle Mustangs and Fast Fords.
http://www.musclemustangfastfords.co...874/index.html
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
Suspension
09-24-2015 10:12 PM
