5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Put the mustang on the scales today
Old 02-11-2012, 07:03 PM
scott4.6
scott4.6's Avatar
Default Put the mustang on the scales today
It was 3156 LBS. Im pretty happy with that ....For now.
scott4.6 is offline
Old 02-11-2012, 07:08 PM
scott4.6
scott4.6's Avatar
Left front was 912 lbs
right front was 903 lbs
left rear was 669 lbs
right rear was 672 lbs
scott4.6 is offline
Old 02-11-2012, 07:15 PM
dwtjr3
dwtjr3's Avatar
What all did you remove?
dwtjr3 is offline
Old 02-11-2012, 07:21 PM
scott4.6
scott4.6's Avatar
just minor things.
Front sway bar and all hardware
light weight alum wheels ( 15x10 and 15x3 .5
the weight off the rear end housing
The metal plate under the steering colum
the little black boxes in the rear wheel wells and all the brackets
Fiberglass hood
spare tire and jack
scott4.6 is offline
Old 02-11-2012, 07:32 PM
dwtjr3
dwtjr3's Avatar
Not bad then
dwtjr3 is offline
Old 02-11-2012, 07:34 PM
scott4.6
scott4.6's Avatar
And a alum driveshaft. My goal is 2900 lbs.
scott4.6 is offline
Old 02-11-2012, 07:43 PM
lizzyfan
Underboss
lizzyfan's Avatar
You can remove the dog bone
lizzyfan is offline
Old 02-11-2012, 07:44 PM
lizzyfan
Underboss
lizzyfan's Avatar
Nevermind, you got it
lizzyfan is offline
Old 02-11-2012, 08:01 PM
scott4.6
scott4.6's Avatar
LOL ,yes it is long gone. I forgot what it was called.
scott4.6 is offline
Old 02-11-2012, 08:27 PM
TRUEBLUE3934
TRUEBLUE3934's Avatar
How much weight did the wheels shave off?
Did you just remove the front bar to go to the track? I wouldn't recommend leaving it off.
If it is weight reduction for passes at the track, I also pull the passenger seat and the rear seat bottom (50 more lbs). The rear seat backs are 15lbs, but slightly more hassle to remove. A gallon of windshield washer fluid in the reservoir is 8lbs. All of that is another 75lbs for passes at the track.
My tailpipes are around 18 more lbs(I don't remember the exact figure off the top of my head). I recently pulled them because I love the deep rumble without the tailpipes.
That is close to another 100lbs available.
A tubular K and control arms will get you around 70lbs reduction.
Good luck in your quest for 2900!
TRUEBLUE3934 is offline
Quick Reply: Put the mustang on the scales today
