5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Loss of Power
Old 03-05-2012, 07:39 PM
cduballstars
cduballstars's Avatar
cool thx nick
cduballstars is offline
Old 03-05-2012, 08:21 PM
cduballstars
ok so i got tcs off and andvantrac off didnt notice the issue but only got through 4 gears i'll test it on the highway tomorrow. obviously tcs is for traction but what does advancetrac do? do i need to keep turning this on/off? if this resolves my issue.
Old 03-05-2012, 09:00 PM
dominant1
dominant1's Avatar
This could be the issue!
http://youtu.be/3sRhm3SsdHM
dominant1 is offline
Old 03-05-2012, 09:33 PM
clowe1965
clowe1965's Avatar
Advance trac is fords stability program, attempts to keep you from fishtailing and general sliding. No you should not have to drive like this, take it to the dealer and get it fixed.
clowe1965 is offline
Old 03-05-2012, 10:25 PM
NickSezz
NickSezz's Avatar
TCS alone keeps wheel spin to a minimum by cutting power and applying the brakes. Advance track monitors steering input, wheels speed, ect.. and applies braking to help keep the car straight. It works very well as a system IMO. You should be able to dive pretty hard with it on, but I have noticed that I get some bogging when it kicks in as I chirp through gears and start to get a little sideways.
TCS off=roast the tires in a straight line.
TCS off ans AC off=write you name all over the street...
If the car is normal with those systems off, then you may possibly have an issue with a sensor somewhere.. unless the car is actually just doing what its suppose to be doing to keep you from hitting a wall, or a cow : )
NickSezz is offline
Old 03-06-2012, 02:04 PM
cduballstars
well it seems to still have a slight bog in 3rd and 4th but i'm gonna take it in to have them look at the car. fingers crossed!
Old 01-05-2014, 02:52 PM
todik@todik.com
todik@todik.com's Avatar
Default Do you still have the same problem with your car
I have the same bog on 5th gear, do you still have it or you got it fixed, what was the issue?
todik@todik.com is offline
Old 01-05-2014, 03:18 PM
Andy13186
Andy13186's Avatar
does the check engine light flash? if so and its kind of studdering it could be the crank position sensor and should be replaced under warranty
Andy13186 is offline
baddog671
07-26-2016 01:20 PM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
09-25-2015 06:58 PM
Quick Reply: Loss of Power
