Anyone using Garmin ecoRoute HD?
Wondering if anyone has tried the Garmin ecoRoute HD on the Coyote engine. I would like to know what gauge choices were available and what the polling rate is like. Looks like it would be a great solution to easily add a lot more engine info and have it conveniently displayed on the GPS.
Info from Garmin:
Info from Garmin:
ecoRoute HD is able to tap in to the OBDII buss of the car and pick out all the real time data. The amount of gauges will vary depending on the car. For example a high end car may have 15 gauges. A small car may have only 4-6 gauges. You can choose up to four custom gauges.
Feature list
RPM meter
Choice of gauges: Fuel Flow, Intake Air Temperature, etc. Coolant/Temperature-Oil/Pressure data Throttle position, Combustion mixture, Engine component operation and status, Battery and charging system information, Climate control information – Heat and A/C etc.
Feature list
RPM meter
alastio
06-09-2006 05:15 AM
